Roof top deck
ChiefuserMathews
Don't use a deck for the room type, use a balcony. Then, define the layers in the room spec dbx. to match the roof construction, then add the layers you need (above) for the platform. You'll probably want to add another floor for this. And yes, the room will still cut the roof, but the room's floor will now match the roof assembly.
  • 3 weeks later...
3 hours ago, ChiefuserMathews said:
Hi Robert,
I was trying to create the molding on the glass panel as you have shown. Unfortunately its not appearing on the glass railing wall, any reason?
Is the layer you drew the molding on turned on in the view you're looking for it ?
