patio tile pattern
ChiefuserMathews
5 minutes ago, ChiefuserMathews said:
then how can i apply the material?
Hey Wilson, if you want someone to be aware of your replies then you need to quote them or tag them using the @ options. You can apply the material to your patio in the room dbx, and use a molding polyline for the border with a separate material. You could also spec that in the room dbx by using a baseboard molding that's say...12" wide by 1/8" high.
On 8/7/2020 at 9:02 AM, ChiefuserMathews said:
s that I select the quote with a + sign which shows a tick mark when I select it
Just click the word quote  and it is sent down to the Replay window .   The  + next too the word Quote allows you to quote more than 1 post.....
You can just use a slab and apply the Patio Pavers from the Catalog or perhaps make some new materials if needed eg look at TechBloc Stone for their Images and Pattern Files...
Mick.
