Hi, I have to draw a guard rail on top of the retaining wall for the below grade entrance stair (image attached). How do I do that. I try to draw a straight rail but you can see in the image. I want them to be on top of the wall. image.thumb.png.8a9b8fb30b58717713964e197fe95654.pngI tried the pony wall option but for some reason I am not getting the result I want. Any help is much appriciated
generate between platforms, perhaps...
2 hours ago, ChiefuserMathews said:
what you mean. I am not an expert in CA
Download a copy of the X12 Reference Manual. Robert was referring to this:
Lots of good info in the Reference Manual. I'm not saying this will solve your issue, but may be helpful.
Like I mentioned this is an exterior retaining wall for a below grade entrance stair and I need a guard rail on top of that retaining wall. That is my challenge
The very fastest way to get help would be to post the plan. Then we can identify exactly what needs to be done instead of using the SWAG method.
Not something I need to do. This uses pony walls.
14 minutes ago, ChiefuserMathews said:
how can i reduce the file size. it is not allowing me to upload the plan file
Did you Zip it?
If your railings are drawn on the 1st floor and define an Open Below room, lower the floor.
Eric, thats exactly what I am trying to achieve. Is that you are creating a room to create that railing. Please excuse me.
Eric, how did you do that? Please guide me.
Thanks to everyone for your help. I had to struggle little bit, had to spend couple of hours. Few more hairs lost. Didn't know the full functionality. Finally found out the way. Hooray !!!
    28425
    ChiefProBrian
    ChiefProBrian
  • Similar Content
    • By ChiefuserMathews
      Hi, could someone please check and let me know what is that thick line showing at the bottom of the stair section? Plan attached for reference
      220002-1.plan
