Wall color change
DH7777
Hello, Is there a way to change the color on all interior walls in one shot? I went into default settings/walls/interior wall/edit and tried changing both material and or wall covering... picked a color and nothing changed. I'm tired of eye dropping the color I want going through the whole house.
When using the material eye dropper you can choose to only change the object you click, change all objects on that floor or all objects in the plan. Just look for the options lower left of screen after you select the material you want to apply.
HA! I never saw this. Thanks!
