jbaehmer Posted July 6, 2020 Share Posted July 6, 2020 Not sure what I am doing wrong (if anything) for this. In the attached files, I have two layouts... 11x17 & 30x42. They both show up good on screen in regards to the space between the sheet edge and the border of the Plans. On the 11x17, it stays the same spacing on the PDF. However, on the 30x42, it looks good on screen, but after the PDF is made, it seems to shift down and to the right. I changed several settings trying to find out what is happening and I am stuck. Hoping you guys may have some luck with it. Fix 30x42 layout.zip Link to comment Share on other sites More sharing options...
rlackore Posted July 6, 2020 Share Posted July 6, 2020 I don't see any problem when I print the 30x42 to PDF: Layout Concept 30x42 - Client Name.pdf Link to comment Share on other sites More sharing options...
madcowscarnival Posted July 6, 2020 Share Posted July 6, 2020 I wasn't able to check the original layout files, but I did open the PDF that rlackalore posted. Just an FYI, my (admittedly old) printer took the border line and some of the text in lower right and title block for page margins. Oddly this happened even printing on a larger sheet, like it needed some minimal margins for the print size regardless of sheet size. Link to comment Share on other sites More sharing options...
jbaehmer Posted July 7, 2020 Author Share Posted July 7, 2020 0 Advanced issue found ▲ 22 hours ago, rlackore said: I don't see any problem when I print the 30x42 to PDF: Layout Concept 30x42 - Client Name.pdf hmmm... at least I know it is a setting I have. May need to re-create it and see if it still happens. Thanks. Link to comment Share on other sites More sharing options...
Rpadge Posted July 7, 2020 Share Posted July 7, 2020 I got rid of my printer a few years ago, but...I seem to remember having to add small lines (I used a plus symbol) on the actual 4 corners of my layout at whatever size I needed (30 x 42, 24 x 36 etc). Otherwise I could not center my plots correctly. You can make them a non-printing color I suppose. Link to comment Share on other sites More sharing options...
