ClarkeThrasher Posted July 1, 2020 Share Posted July 1, 2020 Is it possible after or as auto floor framing is activated to change the joist direction in just one room? It seems as though CA wants all joists to go in one direction throughout a home design structure even when it results in very long spans that would not customarily be framed that way in new or old construction. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 1, 2020 Share Posted July 1, 2020 In X12 it is now possible to frame individual rooms but you may be able to add Joist direction and Bearing lines in X11 and get what you need. M. 1 Link to comment Share on other sites More sharing options...
rgardner Posted July 1, 2020 Share Posted July 1, 2020 F1 key is magic! 1 Link to comment Share on other sites More sharing options...
ClarkeThrasher Posted July 1, 2020 Author Share Posted July 1, 2020 Thanks, Kbird1, I will study up on bearing lines I don't believe I've ever encountered the need. And thank you, rgradner, I will upgrade to 12 asap. Link to comment Share on other sites More sharing options...
Rpadge Posted July 1, 2020 Share Posted July 1, 2020 one tip, you need to have at least 2 framing direction lines (in different directions) before you get the framing to change Link to comment Share on other sites More sharing options...
