cjones1680 Posted June 23, 2020 Share Posted June 23, 2020 Hello, I am stuck with my roof trying to figure out how to create a double gable. Attached is a screenshot what I have with the blue lines showing what I'm trying to do, as well as a floor plan view. Any help would be greatly appreciated! Thank you, -Courtney Link to comment Share on other sites More sharing options...
tommy1 Posted June 23, 2020 Share Posted June 23, 2020 Place the roofs as your penciled it. Draw it manually if you need to and raise the pitch as you show. You'll probably need to move the window a little too. I would be happy to do a one on one meeting via Zoom to show you if you like. 832-754-6160 Link to comment Share on other sites More sharing options...
cjones1680 Posted June 23, 2020 Author Share Posted June 23, 2020 I think the problem is that I'm only using the Home Designer Suite version and don't have the advanced tools of Premier/Architectural...? If it's possible in my version, could you please send screenshots? Link to comment Share on other sites More sharing options...
tommy1 Posted June 23, 2020 Share Posted June 23, 2020 Someone with that version will have to step in. Not sure what you can do. Pretty sure with Pro, you can do it. Link to comment Share on other sites More sharing options...
cjones1680 Posted June 23, 2020 Author Share Posted June 23, 2020 Ok, thanks. While I have your attention, how would I go about clipping this wall with the stairs? Link to comment Share on other sites More sharing options...
Ridge_Runner Posted June 23, 2020 Share Posted June 23, 2020 I know you did not ask for any design input, but looking at you attached picture the two 2nd story roofs (gable and front hip) really need reworked; they are going to be trouble down the road and gutters will almost be impossible to install between them with the eaves so close together. I would probably bring the 2nd floor front wall (hip), which is to the right of the 2nd floor gable, over to meet the side wall from the gable and totally eliminate that space between the two exterior walls; been down this road before. Just my 2 cents. Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 23, 2020 Share Posted June 23, 2020 8 hours ago, cjones1680 said: While I have your attention, how would I go about clipping this wall with the stairs? In plan view place the wall you wish to "clip" directly underneath the edge of the stair object instead of beside it like you have in your posted image. Once done that action will cause the stairs to clip that wall underneath the stair object. I agree with Eric in that hardly anyone here uses any Home Designer Software and certainly not Home Designer Suite. You are better off posting at Home Talk instead of here. DJP Link to comment Share on other sites More sharing options...
