SEAMLESS TEXTURES using Gimp
Kbird1
Tip Added here after being found buried in a post in the Q&A Section as I thought it would be useful for Others, Thx Chopsaw.
        *I have also added some PDFs and links for GIMP.
Making SEAMLESS TEXTURES using Gimp.                    * this info is in the PDF below too
 It's an open source (free) photo editing software available at https://www.gimp.org
Tutorials are here : https://www.gimp.org/tutorials/
Direct link as of :
Mar.13th 2023
https://download.gimp.org/gimp/v2.10/windows/gimp-2.10.34-setup.exe
1. Open the image file in Gimp.
2. Edit > Copy, then Edit > Paste as new layer.             Paste it as a new layer three times so you have a total of four copies, each on their own layer.
3. Image > Canvas Size. Exactly double the width and height of the image/canvas size.
4. Use the alignment tool to align each layer in its own corner (so they are all visible, not overlapped).
5. Use the "flip" tool to reverse/mirror three of the layers. Leave the top-left corner alone.
        Reverse the top-right corner horizontally.
        Reverse the lower-left corner vertically.
        Reverse the lower right corner horizontally and vertically.
6. Export the new image. This will now be a seamless texture when tiled. Choose it as the texture file for your material.
7. Adjust the scale of your new material since the size of the image is now larger.
* the Info above is in the PDF below too
SEAMLESS TEXTURES USING GIMP.pdf
I also made a PDF of the Latest Release Notes
GIMP 2.10.20 Release Notes.pdf
Mick
  • Like 3
Perhaps as you try and Practice with Gimp , you'd like to Share some Seamless or Other Textures with other Chief Users? then I think this Thread would be a good Place to put them as there is no Forum dedicated to such matters.
2560x1440 Black and White (IR) Screen Background I made following the 1st Gimp Basic Tutorial of a recent SpaceX launch.
 Space_Launch_IR_Small.thumb.jpg.209aa476ec4c1356d1ca8b13f708fbd3.jpg  The Full sized File :  Space_Launch_IR_Small.zip
  • 1 year later...
Direct link as of June 20th 2020 ( we then post was made) to latest version of Gimp.
https://download.gimp.org/mirror/pub/gimp/v2.10/windows/gimp-2.10.20-setup.exe
Jan.29th 2022
https://download.gimp.org/mirror/pub/gimp/v2.10/windows/gimp-2.10.30-setup.exe
Mick
Hi there, this might seem like a dumb question, but my experience with photo editing software is near zero, how do I exactly use alignment tool to move each layer to the corners?
And if you can tell me this I am sure I will need to know how the flip tool works.
Much appreciated, Mick.
These are Actually Chopsaw's Instructions , I just re-posted to the Tips Sections     @Chopsaw
I've been using Pixplant for a couple of years now , Ver.5 also does PBR Materials and Texture Maps, so I figured for the $39 Single User Price it was worthwhile.
https://www.pixplant.com/index.php
Mick.
