Treehouse2339 Posted June 20, 2020 Share Posted June 20, 2020 I just upgraded to Premier 12. In 11 in the window schedule tab you had an option to include or exclude from the window schedule. Is there new way to do that? Link to comment Share on other sites More sharing options...
Chopsaw Posted June 20, 2020 Share Posted June 20, 2020 1 Link to comment Share on other sites More sharing options...
Treehouse2339 Posted June 20, 2020 Author Share Posted June 20, 2020 Thanks Chop Saw... Link to comment Share on other sites More sharing options...
Dermot Posted June 20, 2020 Share Posted June 20, 2020 Quote ...in the window schedule tab you had an option to include or exclude from the window schedule. Use the schedule panel on the window specification dialog if you want to exclude a particular window from a schedule. You can also use the schedule panel to treat the window like a different kind of object for schedule purposes. For example, if you have a mulled unit, you can choose to have this go to either the window schedule, the door schedule, or even some other schedule now. If you want to exclude or include a particular type of window, you should do this in the schedule dialog. You will need to click on the little arrow to expand or collapse an include category. In X12, you are allowed to put any kind of object that can go into a schedule into any schedule type which is why the Categories to Include has been expanded. Link to comment Share on other sites More sharing options...
