kintaro Posted June 11, 2020 Share Posted June 11, 2020 I have been using X12 for a long time on a daily basis. I have a strong machine with a strong gfx card. Starting today, whenever I try to load any of my plans, it fails when opening the camera with the following error. When I try a brand new plan with 4 walls, it works. Does it happen to anyone else? I tried dozens of my plans, they all fail on camera view A serious error occurred. Do not save the file in its current state. If you want to try saving your work, use Save As to create a new file. Please restart the program and contact Technical Support. Assertion failed: A serious error occurred. Do not save the file in its current state. If you want to try saving your work, use Save As to create a new file. Please restart the program and contact Technical Support. C:\p4sync\dev\Releases\22.2\chief\source\ChiefQtApplication.cpp(251): Error #272000999 Build: 22.2.0.54x64 --------------------------- Link to comment Share on other sites More sharing options...
Dermot Posted June 11, 2020 Share Posted June 11, 2020 This sounds like it is the result of a system issue, such as a video card or driver issue. See if this tech article helps: https://www.chiefarchitect.com/support/article/KB-00106/troubleshooting-3d-camera-view-display-problems-in-chief-architect.html If all else fails, then contact our technical support department during our normal business hours: https://www.chiefarchitect.com/support/ Link to comment Share on other sites More sharing options...
Kbird1 Posted June 11, 2020 Share Posted June 11, 2020 Please post your Nvidia Driver Version or add it to your Sig. there have been many reports of this, this week , so either a new Nvidia Driver is causing it or the new Windows 10 Update to Version 2004 has caused it .... I am thinking. I don't have 2004 , and no issue here ( yet) so perhap it is Windows 10 2004.... Nvidia Driver 446.14 here Link to comment Share on other sites More sharing options...
kintaro Posted June 11, 2020 Author Share Posted June 11, 2020 I believe this is not a Video card issue as it works when I try a new plan with a simple wall Looking at windows updates I had the past few days, * VC++ 2010 redist security fix * This update: https://support.microsoft.com/en-us/help/4560960/windows-10-update-kb4560960 Forceware driver: 419.72 Win10 version 1909 (build 18363.900) Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted June 11, 2020 Share Posted June 11, 2020 yes, I had the same issue, had to update my driver. still a takes a while to generate the camera view. I never had that issue before. Upgraded to Win10. Let me see how it goes Link to comment Share on other sites More sharing options...
Kbird1 Posted June 12, 2020 Share Posted June 12, 2020 7 hours ago, kintaro said: I believe this is not a Video card issue as it works when I try a new plan with a simple wall Looking at windows updates I had the past few days, * VC++ 2010 redist security fix * This update: https://support.microsoft.com/en-us/help/4560960/windows-10-update-kb4560960 Forceware driver: 419.72 Win10 version 1909 (build 18363.900) Nvidia Driver is at least a year old, so might be worth trying the most recent version. https://chieftalk.chiefarchitect.com/topic/26750-using-camera-causes-program-x11-to-quit-responding/?do=findComment&comment=214651 I have the second M$ update same as you and no issues here... Win10 2004 has issues with some Hardware Drivers , which is why M$ has delayed it's distribution now , but you don't have it. M. Link to comment Share on other sites More sharing options...
kintaro Posted June 12, 2020 Author Share Posted June 12, 2020 Updated to forceware 446.14 - It works!! I have no idea why it stopped working out of a sudden. I assume some update conflicted with the old driver Thank you all for helping! Link to comment Share on other sites More sharing options...
CV-reno Posted June 12, 2020 Share Posted June 12, 2020 For what it's worth, I have had two instances where I got the OP's message. Both times I thought it was time to reboot, just in case, only to see when I restarted that I had some pending Microsoft updates. Once restarted, those same plans let me open camera views without problem. So I suspect some updates temporarily interfere with programs that make heavy use of the video cards. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 13, 2020 Share Posted June 13, 2020 4 hours ago, CV-reno said: So I suspect some updates temporarily interfere with programs that make heavy use of the video cards. Not just Programs, Windows Update also Updates Drivers - if you allow it too - which means the Nvidia ( or Intel or AMD) GPU could be effected too. If you prefer to control it yourself you can disable Windows Update Driver installations - see a tutorial here : https://www.tenforums.com/tutorials/48277-enable-disable-driver-updates-windows-update-windows-10-a.html For Nvidia , Geforce Experience will keep the Driver updated, if you don't want to do it yourself. M. Link to comment Share on other sites More sharing options...
