Resolvetheissue Posted June 4, 2020 Share Posted June 4, 2020 How many passes should it take to do a ray trace? How long should it really take to do a full ray trace? Why am I seeing so many people with this issue that it takes over 2 hours to create one ray trace? I see that people have errors and some don't? What are cause this issue? By turning things on or off does that really help? Are there hidden values in the program that are causing this issue? Could there be to many Camera shots? could there be to much movement in the motion of the camera shots? Do you really need to limit what you do in the program when make the house plans? Does customizing cause this issue? What short cuts can make this easier on everyone? can we see changes of this in the future to the ray trace? can switching from one version to another, cause this issue for the ray traces to take to long? I have some many more questions I will finish here for now. Please help? Link to comment Share on other sites More sharing options...
Kiwideziner Posted June 4, 2020 Share Posted June 4, 2020 too many questions, try the F1 key to learn about raytracing. what version of the program?? what are your computer specs?? just some of the reqd info to start answering. Link to comment Share on other sites More sharing options...
Electromen Posted June 4, 2020 Share Posted June 4, 2020 1 hour ago, Resolvetheissue said: How many passes should it take to do a ray trace? I usually do 10 How long should it really take to do a full ray trace? Depends on many facrtors, turn off unused layers Why am I seeing so many people with this issue that it takes over 2 hours to create one ray trace? I see that people have errors and some don't? I don't What are cause this issue? N?A By turning things on or off does that really help? YES Are there hidden values in the program that are causing this issue? Third party 3D images Could there be to many Camera shots? One per Ray Trace could there be to much movement in the motion of the camera shots? I don't understand Do you really need to limit what you do in the program when make the house plans? NO Does customizing cause this issue? What short cuts can make this easier on everyone? can we see changes of this in the future to the ray trace? can switching from one version to another, cause this issue for the ray traces to take to long? I have some many more questions I will finish here for now. Please help? Link to comment Share on other sites More sharing options...
Dermot Posted June 4, 2020 Share Posted June 4, 2020 Quote Depending on the size of your model, the number of lights present, the quality settings that you are using, and the final image size that you have specified, this can take a very long time for the simple reason that the program is being asked to do a great deal of work. You can find more information in this article: https://www.chiefarchitect.com/support/article/KB-00010/speeding-up-a-ray-trace.html I would also recommend these videos: https://www.chiefarchitect.com/videos/playlists/103/ray-trace.html 1 Link to comment Share on other sites More sharing options...
