Adding floors with CA Interiors
carowe
I am currently working on the interiors for a 3 story house and have done each floor as a separate plan.  The architect has asked whether it would it would be possible to "walk" the client through the entire house starting at ground level since we are now doing this remotely.  I need to at least add the third story to the second story in order to do the cathedral ceilings in several of the rooms.  Is it possible to take the plan for the 3rd floor and add it to the second floor?  And then insert the ground floor under the first floor?  And can I do all this just using interiors?  I've been working on it for several days off and on and I'm obviously not doing something correctly.  Any help would be greatly appreciated!
Is there a limit on number of floors in Interiors?
Why do each floor in its own plan and not in the same plan?
How are you trying to merge the 3 plans? If there is a common location on the various levels it should be easy to point-to-point into position.
Originally I was hired to do the kitchen and baths on each floor, so to keep file size down, just did them separately.  Now the scope has changed and actually this morning did a 3 story so I can do that.  I'm just trying to figure out how to add the plans with the kitchen and the baths to each other.  I have to be honest, I've never tried to do anything like this before.
I would recommend Edit all areas on floor copy and paste into the new joined plan.  Use the align to wall below and above if any are slightly off.  Will take some tinkering though.
I'll give that a try!  Right now when I try to paste the second floor over the first, they overlay each other, so my guess is I should have started out building it by floor instead of separately.
Start a new plan. Create your 3 floors setting defaults (ceiling heights etc) as you go.
Open the 1st floor plan, use Edit Area to copy and then paste into the new plan.
Place a Point Marker where the 1st and 2nd floors align, the copy the point marker to the 2nd floor.
Copy the 2nd floor to the new 2nd floor and use point-to-point move to locate it over the 1st floor.
Do the same for the 3rd floor.
you will need to create the 2nd floor and use the create from blank option and then paste, then align using the reference layer tool.
This is the way I would do it - and do. Placing a reference line in the plan and using "edit area" to copy from give you a known point for your moves and makes the alignment accurate without having to edit wall locations, etc. very much. I usually draw the start of the reference line where I want the point to point move to begin and then draw the end of the line out at say a 45 degree so I can visually pick it up more easily. Make sure to do your point to point move while your copy in the new plan is still selected; makes the entire operation much easier. Quicker to do than to type this dissertation.
    30077
    DznrDavid
    DznrDavid
  • Similar Content
    • By QuadraCadDesigns
      Offering Drafting & Design Services using Chief Home Designer Pro 2019 & Chief Architect X2
      Check out my feedback on Upwork.com with the link below
      https://www.upwork.com/freelancers/~01678a23bb159e53a0
      Rates $15.00/hr
      References Available
      Thanks
      Lee Trahan
      Quadra-Cad Designs
      (207)509-8453
    • By Christina_Girerd
      I've never really done walk-throughs before, haven't felt the need.  But after seeing how much my clients love the new panoramas, I decided to look at walk-throughs again for a project that isn't really suitable for a panorama, especially since I haven't checked them out in several versions.  I'm now using X9.  I watched a couple Chief tutorials, downloaded the XVID 1.3.4 codec, set that in preferences, and set up some walk-throughs and then tried to record various options as I learn how this works.  I am using Windows Media Player for viewing after finding out that "Movies & TV" gives a "Can't play" error message for all the resulting walk-through files.  (Interestingly, when I had the XVID 1.3.2 codec installed, there were a couple avi files I could watch with the Movies & TV app.)
      In a brand new test plan, (all preferences as default except for changing to the 1.3.4 XVID codec), I set up a short 3 camera walk through of a one room space and I found I could not make a viewable .avi file from the following options:  Standard, Painting, or Duotone.  However I was able to successfully record and view .avi files for Vector, Glass House, Technical Illustration, Watercolor and Line Drawing options.  I would like to be able to record and view in the Standard format.  Any suggestions?  Thanks...
    • By wolfgang34
      I like to add music to my walk-throughs. CA support says, "we don't have this functionality"
      Well, I kind of knew that, but that was all the answer I got.
      Does anybody know how to do this as a "peripheral" to Chief?
      Wolfgang
      Vers 6 to X6 / Windows 7 Prof / SP 1 / 64 bit OS
      Processor: AMD II X2 245 / 2.90 GHz
