Landtech Posted May 13, 2020 Share Posted May 13, 2020 Recently I upgraded to the newer version of Chief (X12). I tried to print my first layout set and instead of printing the 4 different elevation views that are shown on my layout- Chief prints the same rear elevation in place of all four. What is even more confusing is this is two separate pages of the layout, which on screen look perfect. Has anyone else had this issue? Is there something I am missing in the new settings? I've included a picture for reference. Capture.MHT Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 13, 2020 Share Posted May 13, 2020 From what you've provided, there's no way to answer your question. We would need to have the Layout and Plan files at a minimum. btw, are you printing to a pdf or directly to a physical printer? 1 Link to comment Share on other sites More sharing options...
mborean Posted May 13, 2020 Share Posted May 13, 2020 Check your page setup. Did you create a PDF first or just print the active screen? I agree with Joe, we need more information. Link to comment Share on other sites More sharing options...
Landtech Posted May 13, 2020 Author Share Posted May 13, 2020 My apologies, I hope this helps. I tried to print from the active screen. I was able to do so in the past but prior to this I have very little experience and it was on X7. alexis duplex.plan preliminary layout.layout Link to comment Share on other sites More sharing options...
Kbird1 Posted May 13, 2020 Share Posted May 13, 2020 It sounds like you have the Layout Boxes Linked to Saved plan views , which have changed in plan , and as Chief always updates the Layout right before printing it is updating the layout to those SP Views. this may help : https://www.chiefarchitect.com/support/article/KB-00882/preventing-views-sent-to-layout-from-changing-when-the-model-is-changed.html 1 Link to comment Share on other sites More sharing options...
Landtech Posted May 13, 2020 Author Share Posted May 13, 2020 Thank you for your help! Link to comment Share on other sites More sharing options...
