Ruby Ceiling macro question X12
BrownTiger
What is the correct or suggested way to create a ceiling macro in X12? (Let's say I want it displayed as x'-y")
Like this for example:
height = (owner.ceiling_elevation-owner.floor_elevation).round(0).to_in
arr =height.divmod(12)
result ="#{arr[0]}'-#{arr[1].round}''" + " CLG.HT."
Or there is a better way to display 12'-5" without the use of divmod?
Define a custom NumberFormarter? etc.
Just looking for suggestions?
I agree with Michael.  Note that you don't need to use .to_in  when using the NumberFormatter.  I actually have several predefined NumberFormatters saved as $Globals so that I can just specify which one I want:
  • $NF_in
  • $NF_ft
  • $NF_ft_in
They are all automatically loaded into memory when I open my Layout (macro in a text box on page 0)
Thank you very much.
#Macro: roomLabel
#X12 Room Macro. Defined global $FtIn
#BT  Output: 13'-0" CLG.HT.
referenced ? obj = referenced : obj = owner
height = (obj.ceiling_elevation-obj.floor_elevation).round(0)
if defined?($FtIn).nil? then
$FtIn = NumberFormatter.new
$FtIn.unit = "'-\""
$FtIn.use_fractions = true
$FtIn.denominator = 8
$FtIn.show_trailing_zeros = true
end
result = $FtIn.apply(height) + " CLG.HT."
LabelTest.plan
    30060
    StephenM
    StephenM
