capitaldesigns Posted April 30, 2020 Share Posted April 30, 2020 I recently replaced my HP Designsjet 750c plus plotter with an HP Designjet T525 36" wide. I was printing a job today and ran out of 36" wide rolls of paper. I have some 24" wide rolls that I loaded up. I need the layout plan to be rotated 90 degrees in order to print on the 24" wide roll of paper. I went into the print dialog and selected portrait for the rotation. The drawing does not rotate. It splits the drawing in half and places half of the drawing above the over half. I also printed as a pdf file and tried rotating the pdf to print the plan. I still could not get the plan to rotated 90 degrees for printing. Does anyone know how I can get the layout plan to rotate 90 degrees so I can print the 36"x24" plan on a 24" wide roll of paper ? Is this an issue with Chief or is it an issue with HP ? Thanks, Mike Link to comment Share on other sites More sharing options...
MoeGia Posted April 30, 2020 Share Posted April 30, 2020 On my HP 110, I have to create a default sheet size for each type of drawing.. (18x24 is rotated to print landscape, 24x36 is not (24" roll)) It's not a function of just changing to portrait or landscape. It's a function of the printer looking for a specific sheet size and orientation. Try creating a new default in the printer setup to see if you get what you need. Link to comment Share on other sites More sharing options...
BrownTiger Posted April 30, 2020 Share Posted April 30, 2020 Using pdf software like Adobe ... More Tools> Tools add "Organize Pages" > rotate.... Just my guess. Link to comment Share on other sites More sharing options...
