How to get fascia/eaves to line up
Jambruins
That fascia alignment issue is always a bit of a problem.  If you want accuracy, then those fascia's need to be modeled manually.  What I typically do is something like this...
  1. Set up an elevation camera that faces the problem fasica
  2. Create a CAD Detail From View
  3. Trace the fascia to create a closed polyline that is the the desired profile
  4. Cut that polyine
  5. Paste Hold Position that polyline back in your elevation view.
  6. Convert that polyline to a polyline solid and position it appropriately in plan view.
  7. Depending on the roof, I either turn the actual fascia off completely or reduce its height to nearly zero
