CAD DETAIL FROM VIEW DIMENSION ISSUE
BILL88
   On 4/19/2020 at 9:08 AM,  joey_martin said:
Once you make a CAD from view, that is no longer a dimension string, it's a bunch of CAD lines and numbers. It won't keep the defaults of a dimension string, because it's not.
Quote
Simply not true.
Well..on my machine they are not dimension strings, they are still dimensions, but all individual dimensions.
Wether they display in, on , or under the dimension line seems to be random.
Have you sent it in as a bug?
1 hour ago, BILL88 said:
Just wanted to thank you all for working so hard trying to help me resolve this issue!
I hope eventually I may stumble on the solution, until then I will deal with it.
Thanks!
On 4/18/2020 at 11:45 PM, Chopsaw said:
Post a test plan file and someone will figure it out. Maybe something we have not thought of until we see the situation.
1 hour ago, glennw said:
Whether they display in, on , or under the dimension line seems to be random.
Any observations as to the type of dimension line used and what it is snapped to ?
The ones I had that were changing to the default display style seem to be also converted to point to point measurements.
For the purposes of the discussion they’re definitely still dimensions and not “CAD lines and numbers”.
