LeRoyWells Posted April 13, 2020 Share Posted April 13, 2020 I am using CA X12 How do I make the block foundation not show up in the garage door space. I am using a pony wall like we build here. Thank you in advance LeRoy Wells Test.plan Link to comment Share on other sites More sharing options...
robdyck Posted April 13, 2020 Share Posted April 13, 2020 I added a doorway in the foundation floor plan. The real question is: why won't the overhead door cut the lower wall of a foundation pony wall? I don't know... Test (1).plan Link to comment Share on other sites More sharing options...
joey_martin Posted April 13, 2020 Share Posted April 13, 2020 This is what I have as soon as I open the plan. What is the problem? Link to comment Share on other sites More sharing options...
joey_martin Posted April 13, 2020 Share Posted April 13, 2020 The other issue is you didn't set the height of the pony wall properly. You were seeing the results of not correctly adjusting your settings. Link to comment Share on other sites More sharing options...
LeRoyWells Posted April 13, 2020 Author Share Posted April 13, 2020 9 hours ago, solver said: Place the door in the block wall, then increase the height. Link to comment Share on other sites More sharing options...
LeRoyWells Posted April 13, 2020 Author Share Posted April 13, 2020 Thank you That did the trick Link to comment Share on other sites More sharing options...
