LeRoyWells Posted April 5, 2020 Share Posted April 5, 2020 CA X12 I have a customer that wants her oven in a stone veneer wall I have tried using a window opening but when I show the room using the cameras the oven does not appear at the front of the wall If someone knows how to do this because a few new customers are now wanting this assembly Thank you Sandra_Davis_Residence_-_Front_Door_Centered.plan Link to comment Share on other sites More sharing options...
LeRoyWells Posted April 5, 2020 Author Share Posted April 5, 2020 Thank you That was the trick Link to comment Share on other sites More sharing options...
joey_martin Posted April 5, 2020 Share Posted April 5, 2020 You will find that there are many different solutions for things like this, but before jumping on here, try using chief EXACTLY like you would build it. You build a wall with stone veneer, frame and hole in it, and place the appliance. It's that simple with most things. Link to comment Share on other sites More sharing options...
MarkMc Posted April 5, 2020 Share Posted April 5, 2020 1 hour ago, LeRoyWells said: CA X12 I have a customer that wants her oven in a stone veneer wall I have tried using a window opening but when I show the room using the cameras the oven does not appear at the front of the wall If someone knows how to do this because a few new customers are now wanting this assembly Thank you Sandra_Davis_Residence_-_Front_Door_Centered.plan Open symbol, options, inserts into wall, set depth. It will frame as well. 3 Link to comment Share on other sites More sharing options...
