door side lites
ChiefuserMathews
You can only change the component sizes for certain window types.  Changing the window type should enable this control.
Custom muntins are not always going to do what you want.  The custom muntins need to cover a certain portion of the window.  So making a cad block with a single muntin probably won't solve the problem.
Stacking two side lites should probably work.  Whether these are fixed windows or fixed doors.
