Designer100 Posted March 15, 2020 Share Posted March 15, 2020 Does anyone know ho fix issues I have on this commercial remodeling addition? 1) Windows and bar cabinets are not against the wall! 2) wall is not showing on full camera looking back toward where it attaches to the existing building. Wall existing is brick on inside, unless I decide to cover it with gypsum bd! 3) I have a 10 ft. plate with 9 ft dropped ceiling 2 ft x 4 ft acoustic tile in new addition. x12 Newell Cheatham Link to comment Share on other sites More sharing options...
Designer100 Posted March 15, 2020 Author Share Posted March 15, 2020 MeetingRoom Remodeling.Addtiona 03.05.2020.zip Link to comment Share on other sites More sharing options...
glennw Posted March 15, 2020 Share Posted March 15, 2020 Why do you have a 120" high stem wall in the new section? I would fix that before doing anything else. Link to comment Share on other sites More sharing options...
Designer100 Posted March 16, 2020 Author Share Posted March 16, 2020 there is 120" to ceiling joists and the ceiling drops 12" (to 9' ) for suspended ceiling. I have tried all I can to get the windows and doors to lay against the wall and to get the existing wall between existing and new addition to show up. Link to comment Share on other sites More sharing options...
Mark3D Posted March 16, 2020 Share Posted March 16, 2020 is that what you want Link to comment Share on other sites More sharing options...
glennw Posted March 16, 2020 Share Posted March 16, 2020 8 hours ago, Designer100 said: there is 120" to ceiling joists and the ceiling drops 12" (to 9' ) for suspended ceiling. Using a 120" hight stem wall will not do what you want. I think you will find that once you change the stem wall height back to zero, all your problems will be solved. Link to comment Share on other sites More sharing options...
Designer100 Posted March 16, 2020 Author Share Posted March 16, 2020 I fixed it. aligned foundation with 1st floor. Link to comment Share on other sites More sharing options...
