Object Eyedropper & Fill Transparency
ACADuser
While the Fill Style Eyedropper is the 'right' tool for this, the object eyedropper should do the same unless those properties are deselected.
The object eyedropper works for me, but not in Alan's plan. I'll dig a bit more to see if I can figure out why not.
The object eyedropper will correctly transfer the fill and the fill transparency, unless the fill of the target polyline is set to "use layer color".
This seems like a bug and should be reported.
The reason it works for me is that I never have a fill set to "use layer color".
And that incorrect function only affects a 'new' polyline. It works on a polyline that has already been 'tampered' with.
3 minutes ago, ACADuser said:
Sorry, I miss spoke. I meant to say "Fill Transparency"
It does fill the new rectangle but with no transparency.
Try it using an initial fill color / pattern that is NOT the 'layer color'. And like I mentioned, if this isn't a bug, it certainly isn't a fully functioning tool for this case (despite the fact that there is a tool specifically for Fills).
