Kiwideziner Posted March 1, 2020 Share Posted March 1, 2020 Just linking up a new layout to my plan file, but when I go tools/ layout/ referenced plan files. which should link all layouts referencing a plan file ie floor / elevations /sections sub floor/ roof etc. It will not hold the selection. I start with each layout file linked to a blank plan file then when I open a new layout from the template file I just have to relink the plan file to have most of my pages populated. in the final release of X12 this is not happening, I have to relink each layout box. Anybody else found this?? I did not see the problem in beta 1. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted March 1, 2020 Share Posted March 1, 2020 Did you do the update that came out shortly after the final release? It was not well publicized. 2 Link to comment Share on other sites More sharing options...
Kiwideziner Posted March 1, 2020 Author Share Posted March 1, 2020 Richard I have build 22.1.0.39 x64 think it is the latest Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 1, 2020 Share Posted March 1, 2020 25 minutes ago, Kiwideziner said: Richard I have build 22.1.0.39 x64 think it is the latest Current version is 22.1.1.1x64 Link to comment Share on other sites More sharing options...
Kiwideziner Posted March 1, 2020 Author Share Posted March 1, 2020 just downloaded that latest one, cant see where it was advertised, just about to see if it was fixed. Link to comment Share on other sites More sharing options...
Kiwideziner Posted March 1, 2020 Author Share Posted March 1, 2020 Thanks guys it appears to be fixed in the latest update. wish CA would make it obvious when there are updates available. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted March 1, 2020 Share Posted March 1, 2020 10 minutes ago, Kiwideziner said: Thanks guys it appears to be fixed in the latest update. wish CA would make it obvious when there are updates available. Under Preferences>General, you can set Chief to check for updates on a daily basis, if you wish. 2 Link to comment Share on other sites More sharing options...
Dermot Posted March 2, 2020 Share Posted March 2, 2020 By default the program should automatically check for updates once a day. If you have turned this off or increased the time in your preferences, then you can always check manually using the menus: Help>Download Program Updates. Link to comment Share on other sites More sharing options...
Kiwideziner Posted March 2, 2020 Author Share Posted March 2, 2020 Dermot I had changed it to 3 days but have never seen anything telling me there is an update unless it is a new version. checking manually is fine but people are too busy to think about doing such things. Link to comment Share on other sites More sharing options...
