Barn1860 Posted January 15, 2020 Share Posted January 15, 2020 Hello I'm new to the chief. I have a pdf file created with Chief Architect that is a blue print design for a house. Can this file be loaded into Chief Architect and changes made directly to this plan? Or is a different type of file needed? It was created with the current version of CA. Thank you. Link to comment Share on other sites More sharing options...
Chopsaw Posted January 15, 2020 Share Posted January 15, 2020 Ask for the Plan and Layout files. .plan & .layout Preferably get the backup version with all textures etc. included. Or you are in for a lot of extra work. Link to comment Share on other sites More sharing options...
Evolution Posted January 15, 2020 Share Posted January 15, 2020 First welcome to the forum. It would be very helpful, if you update your signature with the CA software version you are using, as variations from one vs to the other may affect the answer. Here is a link to how to: https//chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk Also include computer info would be helpful for those who might respond. If you have a PDF file of a plan, then you open a new plan, >import>pdf and then you can trace over. I know there are programs that can convert PDF to .DWG or .DWF files, but if you don't or can't, then the trace over is the way to go. https://www.chiefarchitect.com/support/article/KB-00018/tracing-over-an-imported-file-to-create-a-3d-floorplan.html Chop is suggesting if you can get the original file of the plan that was drawn using CA, then ask for the complete back up. If you're new, to CA you may not understand so go to the help files and search for saving files importing / exporting files etc. Link to comment Share on other sites More sharing options...
Barn1860 Posted January 16, 2020 Author Share Posted January 16, 2020 Thank you SO VERY MUCH for your replies. I've been trying to find a local draftsperson in Queensbury or Glens Falls NY but normal searches on google have been unsuccessful. Is there a way to locate anyone thru this forum? Thank you again. Link to comment Share on other sites More sharing options...
rgardner Posted January 16, 2020 Share Posted January 16, 2020 13 minutes ago, Barn1860 said: Thank you SO VERY MUCH for your replies. I've been trying to find a local draftsperson in Queensbury or Glens Falls NY but normal searches on google have been unsuccessful. Is there a way to locate anyone thru this forum? Thank you again. Check the services offered section of this forum or post in services wanted. Link to comment Share on other sites More sharing options...
