mattyt12 Posted December 15, 2019 Share Posted December 15, 2019 After the rectangular polyline tool is selected and you click in open space on the plan it drops in a default square 600x600 or 2 feet x 2 feet, is there anywhere that this can be altered? Link to comment Share on other sites More sharing options...
Chopsaw Posted December 15, 2019 Share Posted December 15, 2019 No I don't believe there is a default for that. However you can click and drag out any size you need. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 16, 2019 Share Posted December 16, 2019 Chopsaw is correct the trick is not to Drop it , just click and drag out whatever size you need as that Default is hard-coded. Link to comment Share on other sites More sharing options...
mattyt12 Posted December 16, 2019 Author Share Posted December 16, 2019 3 hours ago, Chopsaw said: No I don't believe there is a default for that. However you can click and drag out any size you need. I appreciate that and hitting tab makes a pretty quick process, just thought I'ld question it Link to comment Share on other sites More sharing options...
