andymcg 0 Posted November 25, 2019 Good afternoon. Does anyone know how to get rid of the sides of the cabinet showing up on the toe kicks? I'm sure there's a setting somewhere that I can't find. It's a constant annoyance and makes our drawings look messy. Thanks! Share this post Link to post Share on other sites
MarkMc 532 Posted November 25, 2019 39 minutes ago, andymcg said: Good afternoon. Does anyone know how to get rid of the sides of the cabinet showing up on the toe kicks? I'm sure there's a setting somewhere that I can't find. It's a constant annoyance and makes our drawings look messy. Thanks! Better post a plan-I'm not getting that in X11 and checked in X9 and not there either. Share this post Link to post Share on other sites
Dermot 566 Posted November 25, 2019 I believe you will only see those lines when you have the layer for "Cabinets, Module Lines" turned on and when the program thinks the side is finished. You could try manually turning the side to unfinished and the extra line should go away. 1 Share this post Link to post Share on other sites
andymcg 0 Posted November 25, 2019 That worked. Thanks so much! Share this post Link to post Share on other sites
