Sign in to follow this
handyman25
windows above roof line
I am having some trouble getting some windows to install above the roof line on the front of the house I am designing . the windows are acting like the are suck under the roof line and will not go any further up . I disconnected the attic walls and pulled the roof back and made the wall a balloon framed pony wall for the split for interior and exterior finishes . Nothing I seem to do is allowing me to install the windows up high on this wall?
Home Designer user? Please go to https://hometalk.chiefarchitect.com/
Otherwise ...
Welcome
It's helpful to know what software you are using as it changes from version to version.
It helps others to have this info in your signature so it's always available. Please see this topic for a signature how to.
https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk
Your asking about a window above a roof line.  I think what you mean is the CEILING not the roof.  But I'm guessing.
1 minute ago, handyman25 said:
Yes that is my problem wall.
Yes it certainly is.  Does it rain where you intend to build ?  Where will the water go ?
Not the concern right now,  but there will be a internal gutter system incorporated into the roof system
Nice warm climate I assume ?
Post your plan file and someone will do their best to find a solution for you.
I pulled back the roof and the ceiling and still nothing . Am I missing something? I was almost thinking I need to create another story for this wall but not sure?
Not at all, central Oregon,lol
Ouch !  This would be a similar situation.
There are lots of experts here but it is hard to say exactly what the issue may be without seeing the plan file.
On Level 2, pull the rear (lowest) edge of the front roof forward and snap it to the front of the wall in question - leave the baseline where it is.
Define that wall as Default Wall Top Height and uncheck the Pony Wall designation - there should be no need for a pony wall - make it an interior wall type (Interior-6 ?).
Open the General Wall Defaults and check Auto Rebuild Attic Walls - or, alternatively, manually draw an attic wall on level 3 over the wall in question.
Open the attic wall, Roof panel and check Lower Wall Type if Split by Butting Roof and select an interior wall type (Interior-6 ?)
Place your windows in the attic wall on level 3 in plan or a 3D view.
Milwaulkee GLENN 2.plan.zip
    27465
    SuzLeigh
    SuzLeigh
