CTB_Russ Posted October 23, 2019 Share Posted October 23, 2019 I am trying to add a bonus room to a single story house...a 1.5 story house and I keep running into problems... I only want a 2nd floor above the garage, but there vaulted ceilings in other rooms. The current challenge is adding transom windows in the vaulted rooms...The model has the upper floor stucture cutting through the transom or not allowing placement of the window beacause the floor of the upper floor is there...these are areas that should not have a floor above. Link to comment Share on other sites More sharing options...
CTB_Russ Posted October 23, 2019 Author Share Posted October 23, 2019 thats exactly what I did Link to comment Share on other sites More sharing options...
Doug_N Posted October 24, 2019 Share Posted October 24, 2019 Then what was the problem? Link to comment Share on other sites More sharing options...
SNestor Posted October 24, 2019 Share Posted October 24, 2019 On 10/23/2019 at 12:13 PM, CTB_Russ said: I am trying to add a bonus room to a single story house...a 1.5 story house and I keep running into problems... I only want a 2nd floor above the garage, but there vaulted ceilings in other rooms. The current challenge is adding transom windows in the vaulted rooms...The model has the upper floor stucture cutting through the transom or not allowing placement of the window beacause the floor of the upper floor is there...these are areas that should not have a floor above. If you want an answer...post the plan...or at least a sample plan. You will get an answer promptly... Link to comment Share on other sites More sharing options...
