Trendsighter Posted October 16, 2019 Share Posted October 16, 2019 Since I started using Chief I've always opened up a new plan using the American Casual template. Now it has disappeared? I've been out working in the field and haven't been designing for about a month. Is the elimination of this something new or did I delete it somehow? (I've attached a screenshot showing the American Casual template that I found in an older video.) Thank you. Link to comment Share on other sites More sharing options...
dshall Posted October 16, 2019 Share Posted October 16, 2019 I suggest taking your last plan and deleting everything and go from there. In fact there maybe some special layer sets you would want to use again for your latest project. Link to comment Share on other sites More sharing options...
Trendsighter Posted October 16, 2019 Author Share Posted October 16, 2019 Thank you for the suggestion. I thought it was a good one but it didn't fix the issue? Regards, Dale Link to comment Share on other sites More sharing options...
Trendsighter Posted October 16, 2019 Author Share Posted October 16, 2019 2 minutes ago, solver said: I have it for X6 forward, but I think Chief stopped including them in X10. Look in these directories for a backup. I'm using Chief X11. With the "Residential Plan" loading I don't seem to be able to use "Default Settings" like I could with the "Casual Plan" template. I've rebooted and no change. Could this have something to do with my SSA expiring 60 days ago and I haven't picked it up again yet? Thank you for your assistance. Link to comment Share on other sites More sharing options...
Trendsighter Posted October 16, 2019 Author Share Posted October 16, 2019 Just now, solver said: No. Did you check the directories I showed? Not yet. I'm using an iMac to run chief. I'll give it a try. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 16, 2019 Share Posted October 16, 2019 I think Eric is right Chief removed them in X10 or X11, but here is a copy of My CA Styles Templates Folder. (zip file down lower) It may not give you YOUR defaults back which was why Scott suggested just using an Old plan you know is good settings wise and just deleting everything out of it. You could also import the Defaults from an old plan you like into a copy of the Residental Template...... CA Style Templates.zip M. Link to comment Share on other sites More sharing options...
Trendsighter Posted October 16, 2019 Author Share Posted October 16, 2019 Thank you. I'll give both methods a try and get back to you. I do know I've used the American Casual template with Chief X11. Dale Link to comment Share on other sites More sharing options...
Trendsighter Posted October 16, 2019 Author Share Posted October 16, 2019 Thank you Kbird. When I try and open up the American Casual template it wants to open it on my Chief X9 edition. and then I get this message: "This license of Chief Architect is currently active on another computer. Chief Architect can be installed on multiple computers, but only one computer can be active at any given time." Use the 'Help > Deactivate License' menu on the active computer. Log in to your Chief Architect account. Now I'm not really happy about having to drop "backward" to X9 just to get that template but I'll give it a try. Thanks again for your time. Dale Link to comment Share on other sites More sharing options...
Chopsaw Posted October 16, 2019 Share Posted October 16, 2019 Dale you are really having a bad day ! Do you have an open with option on your Mac like PC's do ? Also there is a new setting in X11 in Preferences > General > File Management > File Association, "Associate Files With This Program.." This is quite helpful if you are exclusively using X11. But this will take away your association with X9. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 16, 2019 Share Posted October 16, 2019 1 hour ago, Trendsighter said: I do know I've used the American Casual template with Chief X11. Your Default Setting for New Plans in Preferences was probably still linked to the X9 folder previously , if you let CA migrate Settings when you update Versions. 46 minutes ago, Chopsaw said: Also there is a new setting in X11 in Preferences > General > File Management > File Association, "Associate Files With This Program.." This is quite helpful if you are exclusively using X11. This should fix it for ALL CA Plans if you open them by double clicking on them, however you can point the Preference for new Plans to the CA Styles Folder wherever you Unzipped it to , and the Amer.Casual Template File. M. Link to comment Share on other sites More sharing options...
