Alaskan_Son Posted October 8, 2014 Share Posted October 8, 2014 I suspect the 3 added light sources inside of the wall cabinets may be what was causing the wall cabinet light leaks. Putting a roof on your plan "might" (??) help as well. I thought that at first as well, I even put it in my post but deleted it when I realized that it looked like those light were actually under the cabinets (from renderings in previous posts), and some of the light leaks were on the walls and not even near the cabinets. Link to comment Share on other sites More sharing options...
CJSpud Posted October 8, 2014 Share Posted October 8, 2014 Michael: He has light sources in the cabinets as well .... above the tube lights under the cabinets. If you select the 3 light sources in plan and check their location for display in camera views, you can see where they are sitting in elevation with a full camera view of the wall cabinets. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 8, 2014 Share Posted October 8, 2014 Michael: He has light sources in the cabinets as well .... above the tube lights under the cabinets. If you select the 3 light sources in plan and check their location for display in camera views, you can see where they are sitting in elevation with a full camera view of the wall cabinets. Good catch Curt. I'm sure that wasn't helping then. I just automatically deleted those lights for my quick test as they didn't seem necessary so you might be right. Link to comment Share on other sites More sharing options...
Vendel Posted October 8, 2014 Author Share Posted October 8, 2014 Thanks Michael, Those three lights IN the cabinets I forgot to delete, those were part of looking for the answer. The light bleeding was there before I put those lights in. Link to comment Share on other sites More sharing options...
Vendel Posted October 8, 2014 Author Share Posted October 8, 2014 Worked out pretty well after al (that means...for a beginner). I replaced the cabinet light for spotlights (with pointlights). Turned off the other lights, and placed a lightsource behind the camera. Link to comment Share on other sites More sharing options...
CJSpud Posted October 8, 2014 Share Posted October 8, 2014 Vendel: Actually, you had four (4) light sources inside your wall cabinets. I found another one before I closed you plan last night. Placing lights inside a cabinet makes sense if you have glazing in the cabinet doors and have stuff you want to show off with some added lighting. Link to comment Share on other sites More sharing options...
Vendel Posted October 8, 2014 Author Share Posted October 8, 2014 Yes, I know. I only placed them there to see if the lightbleeding would stop. But when I saw no changes, I forgot to delete them. Link to comment Share on other sites More sharing options...
CJSpud Posted October 8, 2014 Share Posted October 8, 2014 Vendel: Your 2nd image looks very nice. Was that a quick trace or a high quality one? How many passes/how much time did it take you. If you could turn down the wattage of the under cabinet lighting, I think it would be even greater. Nice job. Here's a ray trace I did after getting rid of 3 of the 4 in-cabinet light sources and deleting a bunch of other stuff in your plan in an effort to speed up the ray trace. I did only 10 "quick" passes and I was still around 40 minutes. I didn't edit the contrast or any other settings. I think adjusting the contrast up just a bit would have made it look better. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 8, 2014 Share Posted October 8, 2014 Here is a 3 min RT. I adjusted the lighting. I also turned off all lights and just used the light sources. Some color would really help this view. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 8, 2014 Share Posted October 8, 2014 This one is 2 min. with some tone adjustments. There was no light leak it was the bar lights reflection. Link to comment Share on other sites More sharing options...
iamfrodo Posted March 12, 2019 Share Posted March 12, 2019 I know this thread is years old but for the sake of people who have this problem: I have the X7 version and I was able to eliminate the glowing indoor edges on walls and cabinets by going to Lighting on Ray Trace Options and unchecking the Enable Environment Light (Outside). Not sure if older versions have the same option though. Link to comment Share on other sites More sharing options...
