DH7777
XVID step by step install for dummies
Can anyone tell how I get XVID or any new codec to install into CA so I can choose it as an option when recording walkthroughs? I need to know the "path" I'm assuming because downloading XVID and installing it just puts in on my computer(somewhere) but not in CA. I'm lost here...
Chief's Reference Manual implies that if it's installed on your system, it should be available:
Have you tried rebooting your system after the codec installation?
Many questions require the need to know which version of the program you are using , so please do your Forum Signature as choosing the Codec is done differently in X11 vs earlier versions for instance.
ie when you save the Walkthrough (X11) vs a Setting in Preferences>Render (X10)
Yes, thanks that was the fix!
Ok. I'm new how do you do your forum signature? Is it in edit profile?
    29350
    sea_lyons
    sea_lyons
  • Similar Content
    • By Renerabbitt
      POST 0
      You've found it! A thread offering up some of my favorite symbols and content for Chief Architect X-11.
      These items are for X-11 only. If you haven't updated yet I encourage you to do so, it's a great release.
      The following content is listed by category with both a link to the post within this thread for easy navigation and a link to a direct download if you won't to cut straight to the chase. new/recent uploads are in RED font
      CLICK ON THE "DL" FOR INSTANT .CALIBZ DOWNLOAD:
      CONSTRUCTION ASSEMBLIES/ARCHITECTURAL ITEMS:
      RABS 42 CABLE RAILING - DL    RABS MODERN FRONT DOOR AND DOOR ASSEMBLY - DL   RABS INTEGRATED SINK - DL NEW!!! 03/26/2020
      ENTOURAGE:
      RABS CHARLES-HILL GROUPED LIVING ROOM - DL RABS CHELTON GROUPED LIVING ROOM - DL    ACCESSORY HOME #1 - DL ACCESSORY HOME #2 - DL ACCESSORY HOME #3 - DL
      KITCHEN RELATED:
      3-ISLANDS - DL LA CORNUE 1908 RANGE - DL CAFE APPLIANCES, PAINTABLE(CORRECTED) - DL
      LIGHTING:
      PENDANTS AND SCONCES - DL-1 - DL-2 - DL-3 - DL-4 RECESSED NC HALO 4 INCH LED WITH HOUSING - DL NEW!! 03-22-20
      MATERIALS:
      TILE AND COUNTERTOPS #1 - DL 1(ONEDRIVE LINK) - DL-2 CUSTOM WHITES WITH PAINT TOOLBAR ICONS - DL-1 - DL-2 - DL-3 - DL-4 - DL-5 - DL-6 RABS RUGS 1V1 - DL          RABS STARTER KITCHEN MATERIALS PACK - DL         RABS FLOORING PACK 1 - DL            RABS OLD GOLDEN OAK FLOOR - DL
      SYMBOLS:
      FIREPLACE ASSEMBLY 1 - DL     ACKLES BED AND EDISON TABLE LAMP - DL-1 - DL - 2 TEAPOT MATERIAL EDITOR REPLACEMENT - DL-1 - DL-2 FINMARK TABLE FROM CB2 - DL FIREPLACE MANTLES 1 AND 2 - DL    RABS STRETCHABLE PICTURE FRAMES - DL    BATH SURROUND TOOLS
      VIDEOS:
      YouTube Channel
      Many of these I have personally made or modified. Some of the content may have been created by others for which I will give credit. Many of the materials have free licensing, so no credit is needed.
      Some of this content may slow down your program as I have a high powered machine and often times use complex and high resolution textures. I will try and give as much detail as possible. Use at your own peril!
      No but seriously dig through and enjoy, I've spent a good number of hours ensuring the quality of these symbols and will update them periodically- so CHECK BACK IN! and PLEASE GIVE A LIKE FOR THE POST OF ANY SYMBOL YOU LIKE, IT ENCOURAGES ME TO GO BACK AND REFINE/REDUCE/OPTIMIZE THAT SYMBOL. GIVE A DOWNVOTE AND IT'LL PROBABLY ENCOURAGE ME TO DO THE SAME THING...YOU'LL JUST BE A JERK FOR IT
      CHANGELOG:(PACIFIC TZ)
      Page 1:
        Post 0:
      02-12-2019- 4:45PM: Removed the poll, migrated this thread. re-uploaded from X11 public beta 02-20-2019-2:59PM: Added a Poll for user content requests 03-30-2020-6:49PM: Deleted Video Links and added link to YouTube Channel   Post 5:
      02-12-2019- 4:45PM: centered the hearth on the symbol   Post 18:
      02-12-2019-9:52PM: Posted and fixed DL links
      Here is a symbol to get you started:
      @Cheryl_C_Crane Think you requested this,
      RUSTIC BRICK 2.calibz
      Number of Textures: 2
      Map size: 1024x1024
      Filesize: 3.13 MB
    • By Kbird1
      June 28th 2020
      *** AS OF VERSION X11 CHIEF HAS ADDED A TOOL TO PREFERENCES TO DO THIS FOR YOU, GO TO
      Preferences > General> File Management > File Association    .........     which is at the very bottom of the TAB.
      ***Dec. 2018***   For X10 and lower versions
      Microsoft has now fixed File associations and you can do it via
      Start>Settings>Apps>Default Apps> scroll down to  Choose Default App by File Type near the bottom (not File Protocol)
      Now scroll Down and find each Chief File type and change the Default to Chief Architect X10 ( or your version )
      X10 should be in the list for each type to choose from for these File Types...
      .alb
      .calib
      .calibz
      .layout           (sketchup maybe associated at times with this one)
      .plan
      .undoplan
      If Chief isn't listed or a choice above it should offer to look for Other Apps....
      so scroll all the way down to "look for other Apps on this PC" (in blue) if X10 is not on the List already and in the Windows Explorer Window go to :
      C:\Program Files\Chief Architect\Chief Architect Premier X10 (64 bit) and select the File Chief Architect Premier X10.exe
      after the 1st File type (.alb above) X10 should be in the list for the Others and you won't need to do this part again.... you can only change one at a time so do these 6 types...
      Mick.
      ***Nov 2018***
      A recent Windows  10 Update has Broken File Associations for Many Programs . not just Chief
      *** EDITED OCT 2018***
      It seems the Methods below may no longer work since the Windows 10 1803 Update in April
      Some other Options are :
      1.) You can also Right Click any .calibz file or .plan or .layout etc  and Choose Open With>CA X10  (scroll Down to bottom if you don't see X10 listed and choose look on PC  (see path below) and Select it, once found look for the Checkbox that says Always Use this App Check it 1st and then hit Ok
      The Default Full Path to the CA X10 Program is
      "C:\Program Files\Chief Architect\Chief Architect Premier X10 (64 bit)\Chief Architect Premier X10.exe"
      2.) You can also goto Control Panel>Default Programs>Select CA X10 and the Repair Button should appear and you can Use it to repairs Files for the Installed Program, this does not effect Settings etc at least not when I have tried it. This is useful if you re-install X9 or one of the Home Designer Products or an older version of CA, AFTER X10 and they overwrite the Defaults For X10.
      To Open Control Panel Right Click START>System> scroll to bottom on the right hand side and Chose System Info under Related Settings. In the top left hand Corner click on Control panel Home>Programs and Features> select Chief Architect Premier X10 (64bit)  and on the Ribbon next to the Organize dropdown Arrow you should see Repair appear, click on it and the Repair will begin. ( it will look like the Installer is running again)
      3.) There is also some Command-line Options available if you are familiar with Dos and the Command Prompt? ask if you need them , I will post them if needed but I don't want people messing their system up by accident.
      Original Method
      The X10 Upgrade does not seem to have reset the Default Application for .Plan, .layout .calib and .calibz , .alb Files, .undoplan to X10, which is why X9 is still opening when you double Click any of these File Types instead, from reading here on the Forum, it looks like it hasn't done this on the Mac OS either Instruction for Mac High Sierra OS are in Post #2
      Chief does not appear to have the ability to re-register default File Types like some Programs do, but it can be done manually via the settings App or Control Panel ( better/easier ).
      In Windows goto :
      >Control Panel\All Control Panel Items\Default Programs\Set Associations
      if that just takes you back to the Settings App , right click the Start Button >Run and it the box copy and Paste this and hit <Enter> :
      control /name Microsoft.DefaultPrograms /page pageFileAssoc
      goto each File extension. ( list below) and click the Change program button at top right.
      scroll all the way down to "look for other Apps on this PC" (in blue) if X10 is not on the List already ( wasn't for me) and in the Windows Explorer Window goto :
      after the 1st File type (.alb) X10 should be in the list for the Others and you won't need to do that again.... you can only change one at a time so do these 6 types...
      .alb
      .calib
      .calibz
      .plan
      .undoplan
      Mick.
    • By pinehawker
      I am drawing a commercial interior and the building has full size coolers.  Once I place them along an exterior wall I need to enclose them in a wall that goes from top of cooler to ceiling.  Any help would be appreciated.  Also anywhere that I can find regular metal wall shelving.  i am using x11 premier    thank you
    • By clarkbreyman
      Working on a very simply model (my first - just a kitchen) in X11 on MBP 13 2018 (16GB ram, Quad i7). I started getting lock ups when using materials and things have progressed to more random lockups opening views and panning.
      The most recent stack trace looks like this at the bottom:
      47  qtrender::CAOpenGLWidget::paintGL() + 169 (CAInterior + 19921801) [0x10befdb89]
        47  QMetaObject::activate(QObject*, int, int, void**) + 2320 (QtCore + 2219168) [0x127728ca0]
        47  qtrender::LayeredCanvasGL::paintLayers(bool) + 183 (CAInterior + 19950759) [0x10bf04ca7]
        47  qtrender::LayeredCanvas::paintLayersCore(bool) + 322 (CAInterior + 19941442) [0x10bf02842]
        47  qtrender::CanvasLayer::doPaint(bool) + 76 (CAInterior + 19922860) [0x10befdfac]
        47  qtrender::CanvasLayer::paint(qtrender::PaintTarget&) + 55 (CAInterior + 30269943) [0x10c8dc1f7]
        47  CanvasPaintGLController::paintGL(qtrender::PaintTarget&) + 164 (CAInterior + 7998116) [0x10b39eaa4]
        47  CanvasPaintGLController::paintScene(qtrender::PaintTarget&) + 727 (CAInterior + 7998983) [0x10b39ee07]
        47  qtrender::PaintTarget::Painter::~Painter() + 31 (CAInterior + 19973631) [0x10bf0a5ff]
        47  qtrender::FramebufferPaintTarget::endPaintImpl() + 121 (CAInterior + 19929321) [0x10beff8e9]
        47  render_engine::RenderableMesh::drawImpl(render_engine::GpuResourceContext&, unsigned long) const + 1154 (libCARender.dylib + 1362338) [0x11f50e9a2]
        47  glDrawArrays_GL3Exec + 254 (GLEngine + 696989) [0x7fff3eff729d]
        47  glrIntelRenderVertexArray + 254 (AppleIntelKBLGraphicsGLDriver + 58310) [0x7fff2c5323c6]
        47  GenContext::ProgramPipeline() + 16522 (AppleIntelKBLGraphicsGLDriver + 76968) [0x7fff2c536ca8]
        47  void updateBindingTable<SGfx3dStateBindingTablePointers>(GenContext*, unsigned int, SGfx3dStateBindingTablePointers&) + 2647 (AppleIntelKBLGraphicsGLDriver + 89325) [0x7fff2c539ced]
        43  IOAccelContextAddResource + 8 (IOAccelerator + 9304) [0x7fff58820458]
       *38  hndl_alltraps + 223 (kernel + 928079) [0xffffff80002e294f]
       *29  user_trap + 684 (kernel + 2512220) [0xffffff800046555c]
       *29  exception_triage_thread + 417 (kernel + 1300561) [0xffffff800033d851]
       *24  exception_deliver + 1295 (kernel + 1299935) [0xffffff800033d5df]
       *23  mach_exception_raise + 269 (kernel + 1692381) [0xffffff800039d2dd]
       *16  mach_msg_rpc_from_kernel_body + 268 (kernel + 1320764) [0xffffff800034273c]
       *16  ipc_kmsg_send + 309 (kernel + 1148453) [0xffffff8000318625]
       *13  ipc_kobject_server + 568 (kernel + 1317272) [0xffffff8000341998]
       *13  ??? (kernel + 1693962) [0xffffff800039d90a]
       *7   catch_mach_exception_raise + 103 (kernel + 1614855) [0xffffff800038a407]
       *3   handle_ux_exception + 387 (kernel + 7494691) [0xffffff8000925c23]
       *2   IOLockLock + 33 (kernel + 2480657) [0xffffff800045da11]
      Kitchen1213B.plan
    • By JeremyKing
      I was wondering if anyone has ever built a script that loads a folder full of additional libraries that were downloaded to your machine instead of spending time clicking on each library.  I am a teacher and have 27 machines and its very hard to keep all of the libraries on all of the machines for the students to browse, and I dont want to have them click and run every single one.  I am looking for a one stop file that does this for them.
      Any help would be great.
      Thanks
