Override Dimension with Text
kwhitt
Is it possible to override a dimension with text?  I see where you can add to the suffix or prefix, but I don't want any numbers and I'd prefer not to draw the dimension lines and architectural ticks manually.  Thanks.
Reduce text size to at or near zero and then add text manually is typically the quickest and easiest way.
