ACADuser Posted September 30, 2014 Share Posted September 30, 2014 I have a stem wall foundation and where the wall is thickened to 16" and joins the 8" wall the foundation does not show the needed 4" area of the foundation. Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 30, 2014 Share Posted September 30, 2014 I am not sure I understand exactly where the '4" ' is required but you can extend the thicker wall 4" or you can draw a slab to extend-fill in any gaps. I suppose you could even use a soffit, solid or other object as well, just fix it with the tools at hand. DJP Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 30, 2014 Share Posted September 30, 2014 Here is how I did it. http://screencast.com/t/DzZTrrnXRDev 1 Link to comment Share on other sites More sharing options...
ACADuser Posted September 30, 2014 Author Share Posted September 30, 2014 Worked perfectly Perry, Thanks Link to comment Share on other sites More sharing options...
