ckirste Posted August 22, 2019 Share Posted August 22, 2019 I just installed the X11 update. Now my menus below the title bar are gone. I'm sure this is really simple, but I don't know where to turn them back on. Though I've been using CA for many years, I've never done a lot of customization, and I've never run into this issue. I've searched help, the forum, and can't find how to turn them on again. Thanks Cait Link to comment Share on other sites More sharing options...
Chopsaw Posted August 22, 2019 Share Posted August 22, 2019 View > Toolbars Link to comment Share on other sites More sharing options...
ckirste Posted August 22, 2019 Author Share Posted August 22, 2019 Hi Chopsaw, Yes, I tried that. Nothing changes. Still Missing Link to comment Share on other sites More sharing options...
ckirste Posted August 22, 2019 Author Share Posted August 22, 2019 Thanks Solver, that worked. -Cait Link to comment Share on other sites More sharing options...
Chopsaw Posted August 22, 2019 Share Posted August 22, 2019 Looks like it may have been the same problem @Renerabbitt had with the previous update. Might be worth sending it in as that should not happen and can be quite devastating for a customized setup that is not backed up. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 22, 2019 Share Posted August 22, 2019 Just now, solver said: The options really should allow the rebuild of custom toolbars and other instead of just a reset to factory configuration. You can always delete or rename your .ini file and then restart and it will bring up the update options again but that only gives you your toolbars from the previous version ( X10 in this case ). Always a smart idea to back things up but a KB article would definitely be helpful unless there is one already ? I suppose what you are asking for is an auto toolbar archive. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 22, 2019 Share Posted August 22, 2019 There does seem to be a backup when updating versions but maybe it should be with every update ? Link to comment Share on other sites More sharing options...
jjwarch Posted August 23, 2019 Share Posted August 23, 2019 I ran into the same problem. I have an older version x7 that does not have the Reset Toolbars option. Any idea to restore the ribbon menu? Thanks. Link to comment Share on other sites More sharing options...
ckirste Posted September 11, 2019 Author Share Posted September 11, 2019 I'm revisiting this thread. My menu tool bar has disappeared again a few times. I can't pinpoint why - if I'm doing something specific. The first time it happened I had done a "save as" command and saved as a new file. That time I reset my preferences (which I agree is not a great way to solve this, but I didn't have much customized). It happened again when I did a save as command, but I was able to use the "View Toolbar" option and it reappeared. Today I had a plan open and the toolbar was fine, then I went away from my computer for a few hours. When I reopened CA the menu toolbar was gone again. The "view toolbar" command doesn't work - no toolbar. I'm going to reset my preferences again... but I'm wondering if anyone else has noticed this with X11. I have opened up a case with support at CA. Link to comment Share on other sites More sharing options...
BrownTiger Posted September 12, 2019 Share Posted September 12, 2019 Toolbars have a backup built-in, but make your own copy ... it takes 10 seconds to restore 1) Find your data folder in preferences 2) Make a copy of your toolbar folder If lost or corrupted -- recopy from the backup Link to comment Share on other sites More sharing options...
ckirste Posted September 12, 2019 Author Share Posted September 12, 2019 Thanks BrownTiger, I'll look at making a backup. I contacted support about the issue. According to them: "Do you have the Chief Architect Premier X11 Data folder stored on a network location (or your Documents folder being saved to One Drive as well)? Do you know if maybe there were Windows updates on the days you lost toolbars? Both of these routes we have seen the toolbars occasionally disappear" Also "Have you been leaving Chief Architect open while the computer goes to sleep? If so, we've also seen that on a rare occasion cause the toolbars to disappear. You might try quitting out of Chief Architect if you know you are going to be away from the computer for an extended period of time to see if that helps at all." My system did update last night when I shut down and this morning was when the toolbars disappeared. Also, I had left CA up when I went to meetings in the morning. Having a back up makes sense because these are pretty normal actions and really shouldn't result in lost functionality. -Cait Link to comment Share on other sites More sharing options...
