Thomen Posted July 27, 2019 Share Posted July 27, 2019 Hi All! I've worked out how to create triangular windows but there's no way to rotate windows which is a massive shame as I'm trying to create a window with the triangular point facing downwards with a flat top. Just wondering if anyone has managed to achieve something like this? In the file attached imagine flipping the triangle on it's vertical axis Thanks! Link to comment Share on other sites More sharing options...
Thomen Posted July 27, 2019 Author Share Posted July 27, 2019 Thanks very much but unfortunately I don't seem to get an option to convert to symbol if I click on the window? I'm using home designer pro 2020 Link to comment Share on other sites More sharing options...
dshall Posted July 27, 2019 Share Posted July 27, 2019 40 minutes ago, Thomen said: Hi All! I've worked out how to create triangular windows but there's no way to rotate windows which is a massive shame as I'm trying to create a window with the triangular point facing downwards with a flat top. Just wondering if anyone has managed to achieve something like this? In the file attached imagine flipping the triangle on it's vertical axis Thanks! I have brought this up before, I am not sure why we cannot do what you are suggesting..... Link to comment Share on other sites More sharing options...
Thomen Posted July 27, 2019 Author Share Posted July 27, 2019 Is it possible to model it elsewhere and import it in? Link to comment Share on other sites More sharing options...
Kbird1 Posted July 27, 2019 Share Posted July 27, 2019 3 hours ago, Thomen said: Is it possible to model it elsewhere and import it in? Sketchup possibly , did you look on 3D Warehouse for one that is already made? this assumes 2020 Pro can import .skp files....? M. Link to comment Share on other sites More sharing options...
Chopsaw Posted July 27, 2019 Share Posted July 27, 2019 3 hours ago, Thomen said: Is it possible to model it elsewhere and import it in? Post your file and maybe someone can make the symbol for you if you don't have that option but can import .calibz ? Link to comment Share on other sites More sharing options...
