mikes616 Posted July 27, 2019 Share Posted July 27, 2019 I have a roof that has no overhang at the eave and has a large fascia & frieze but the gable ends just have a 1"x6" trim board. Somehow, when I build the roof that way, the trim on the gable end becomes as large as the fascia. I want the 1x6 trim on the gable ens. See attached. Any suggestions? Thanks. Mark Link to comment Share on other sites More sharing options...
Greg_NY61 Posted July 27, 2019 Share Posted July 27, 2019 Post a plan Link to comment Share on other sites More sharing options...
mikes616 Posted July 27, 2019 Author Share Posted July 27, 2019 hope this one works 21904B.plan Link to comment Share on other sites More sharing options...
StephenGreene Posted July 27, 2019 Share Posted July 27, 2019 On 7/27/2019 at 9:31 AM, mikes616 said: I have a roof that has no overhang at the eave and has a large fascia & frieze but the gable ends just have a 1"x6" trim board. Somehow, when I build the roof that way, the trim on the gable end becomes as large as the fascia. I want the 1x6 trim on the gable ens. See attached. Any suggestions? Thanks. Mark Expand you have the frieze on the gables at 11" and the fascia on the eave at 11". adjust accordingly. Link to comment Share on other sites More sharing options...
mikes616 Posted July 27, 2019 Author Share Posted July 27, 2019 How do I add a frieze under the eave? Sorry if this is a dopey question. Mark Link to comment Share on other sites More sharing options...
mikes616 Posted July 27, 2019 Author Share Posted July 27, 2019 Thank you, Eric. Totally overlooked the option! Mark Link to comment Share on other sites More sharing options...
SNestor Posted July 27, 2019 Share Posted July 27, 2019 On 7/27/2019 at 9:31 AM, mikes616 said: I have a roof that has no overhang at the eave and has a large fascia & frieze but the gable ends just have a 1"x6" trim board. Somehow, when I build the roof that way, the trim on the gable end becomes as large as the fascia. I want the 1x6 trim on the gable ens. See attached. Any suggestions? Thanks. Mark Expand On 7/27/2019 at 2:34 PM, solver said: And one more. Consider a molding instead of solids for this trim. Expand As Eric suggested above...you might consider using molding lines to create the lattice panel under the porch... You may also want to watch my video on building porches with columns...the columns on your front porch are hanging over the front edge of the Porch. The fix is fairly simple. Link to comment Share on other sites More sharing options...
