Dashed door swing?
Tdgdesign
18 hours ago, Chopsaw said:
Here is another idea that is a little more precise.
Plus I needed to try out my new high speed internet connection :D
Similar idea...
  1. CAD Detail From View.
  2. Select one of the opening arcs.
  3. Group select others using Match Properties>Layer (Doors) and Object Type (CAD Arc)
  4. Change line style to dashed, slightly heavier line weight, and color white.
  5. Cut
  6. Switch back to normal Plan View and Paste/Hold Position
  7. Bring Forward if necessary using View Draw Order Edit Tools
