DenisonDrywall Posted July 11, 2019 Share Posted July 11, 2019 How do i get exterior window trim to be on 3 sides of the window (sides and top not bottom)? so the stone can be right along the bottom of the window like in this image. thanks, Link to comment Share on other sites More sharing options...
country Posted July 11, 2019 Share Posted July 11, 2019 Those window look like they have no casing and are recessed to the sheathing layer. Link to comment Share on other sites More sharing options...
robdyck Posted July 11, 2019 Share Posted July 11, 2019 That particular picture has no window trim. The stucco and the stone are finishing right up to the window frame. In order to get a proper stone sill at the bottom of windows, or at the top stone (in this case the same thing) you'll have to make it. I use a molding p-line to place my own stone sills that are sized to match the actual products used (in my region). Link to comment Share on other sites More sharing options...
DenisonDrywall Posted July 11, 2019 Author Share Posted July 11, 2019 yes, the picture is EIFS w/ no window trim. I am doing siding w/ window trim and was hoping to not have to "make it" myself but i guess that is what i need to do. Thanks, Link to comment Share on other sites More sharing options...
Evolution Posted July 11, 2019 Share Posted July 11, 2019 Jennifer, if it would help, you can open your window DBX select your exterior molding (from the library or make one) then select sill on exterior, which will automatically make your exterior casing on 3 sides. Then go to the sill, select a different one from the Library, or making a molding profile you want to use and save it in your user library, and replace the sill with your custom one, you can also select the material (if your using stone from the library or if you imported or made a new material for the stone, change the sill material to stone). I'm by no means an expert with the software, but just thought this idea might help? Link to comment Share on other sites More sharing options...
DenisonDrywall Posted July 12, 2019 Author Share Posted July 12, 2019 yes that worked. thank you. i did have to click to not have an apron. Link to comment Share on other sites More sharing options...
