Electrical Schedule
EsteeChief
That is the only problem with the schedules with all of them, if you have different floors put the make a schedule for each floor. put them on that floor and that will shorten them
What I would do is make a copy of the plan on the layout page, then one of the copies select it and select the scale tool and make it not to scale then you can move the selected boundy and move them until only the that schedule is showing and then up the top icon select the resize icon and adjust to fit the only thing that happens is it is not to scale
Same answer as the other thread:
I know how to easily resize the schedule in both directions at once if that helps.
Select the schedule, shift select the symbol again.
Grab the small top centre grip and drag it down.
  • 1 month later...
  • 4 weeks later...
    30404
    willmick
    willmick
