ClarkeThrasher Posted June 10, 2019 Share Posted June 10, 2019 I can't rotate a wall section I sent to a layout page of a plan, it has no handle as a floor plan or other views sent to layout will have. Is there not a way to do this? Link to comment Share on other sites More sharing options...
Chopsaw Posted June 11, 2019 Share Posted June 11, 2019 You can rotate the entire view in layout if there is a justifiable reason for it but if you need to rotate a wall it should be done in plan view. Link to comment Share on other sites More sharing options...
ClarkeThrasher Posted June 11, 2019 Author Share Posted June 11, 2019 2 hours ago, Chopsaw said: You can rotate the entire view in layout if there is a justifiable reason for it but if you need to rotate a wall it should be done in plan view. No, Chopsaw, I'm sorry I probably did not explain my problem adequately. It's a Cross Section/Elevation Entire Plan/View or Current Screen (makes no difference) sent to a Layout Page in Scale or Fit to Page (makes no difference). The need is a desire to have several Cross Section/Elevations on the same layout page and rotating will allow more space on the page for other cross sections. Has nothing to do with rotating a wall or object or anything within the plan, a Wall Section, to be sent to Layout. If there is not a simple quick way to do this, it seems like a pretty significant oversight, would be the second time within a week I have stumped Technical Support. Link to comment Share on other sites More sharing options...
Chopsaw Posted June 11, 2019 Share Posted June 11, 2019 Ok that should not be an issue. Likely tech support just did not quite understand the situation but I think I do. Select the "Layout Box" in Layout and there should be a small triangle outside the perimeter that you can grab and rotate the whole box ( view ). When selected they can also be rotated with the transform and replicate tool. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted June 11, 2019 Share Posted June 11, 2019 Pardon my ignorance, but would this not be confusing to the trades to have some views oriented one way and others oriented 90 degrees on the same page? Maybe I don't understand what you are trying to do. Link to comment Share on other sites More sharing options...
ClarkeThrasher Posted June 11, 2019 Author Share Posted June 11, 2019 31 minutes ago, Chopsaw said: Ok that should not be an issue. Likely tech support just did not quite understand the situation but I think I do. Select the "Layout Box" in Layout and there should be a small triangle outside the perimeter that you can grab and rotate the whole box ( view ). When selected they can also be rotated with the transform and replicate tool. The small triangle is what I meant by a “handle” in my first post, there ain’t none. Link to comment Share on other sites More sharing options...
Chopsaw Posted June 11, 2019 Share Posted June 11, 2019 3 minutes ago, ClarkeThrasher said: The small triangle is what I meant by a “handle” in my first post, there ain’t none. They are sometimes hard to find if there is something already on the page but it should be there. Transform and replicate as a backup if there is an issue it can be sent in to tech support. Link to comment Share on other sites More sharing options...
ClarkeThrasher Posted June 11, 2019 Author Share Posted June 11, 2019 31 minutes ago, Ridge_Runner said: Pardon my ignorance, but would this not be confusing to the trades to have some views oriented one way and others oriented 90 degrees on the same page? Maybe I don't understand what you are trying to do. Not to this trade it wouldn’t be. Seriously, we trades are not that stupid. If one can understand the whole wall section concept, this would be a piece of cake comparatively. One can just rotate the paper plan if ones viewpoint is challenged. Link to comment Share on other sites More sharing options...
ClarkeThrasher Posted June 11, 2019 Author Share Posted June 11, 2019 4 minutes ago, solver said: Posting a image or 2 and the layout and plan files will help others help you. Surely you understand what I am saying, solver? Honestly, I felt as if anyone who had ever taken a plan to layout would understand. Plus, I felt sharing my work content could just extract unwanted, irrelevant, tangential critiques. But if I have to, I’ll get up and do it, yet as I think it through, how does one show what is not there, the little triangle thingy? Screen shots I guess, so I’ll have to learn how to do frigging screen shots! Link to comment Share on other sites More sharing options...
Chopsaw Posted June 11, 2019 Share Posted June 11, 2019 The little triangle should show up centered out beyond the edge of the box you select, maybe convenient sometimes but a little random if you don't understand what is going on and where to look. Link to comment Share on other sites More sharing options...
ClarkeThrasher Posted June 11, 2019 Author Share Posted June 11, 2019 2 minutes ago, solver said: Link to comment Share on other sites More sharing options...
Chopsaw Posted June 11, 2019 Share Posted June 11, 2019 Humm... No option for a section view. Have you done that in previous versions ? Workaround would be to rotate your drawing sheet, and yes that is a pain. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 11, 2019 Share Posted June 11, 2019 You can rotate Plan Views I am not 100% sure about Sections or Elevations though ( no?) ..... BUT send a CS or Elevation to a CAD Detail 1st and you can..... M. 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted June 11, 2019 Share Posted June 11, 2019 7 minutes ago, Kbird1 said: You can rotate Plan Views I am not sure about Sections or Elevations though..... BUT send a CS or Elevation to a CAD Detail 1st and you can..... Amazing how screen shots work. Nice idea Mick. A lot less work than rotating the drawing sheet unless you need it to be live as there does not seem to be an update cad detail button. All depends on what you need and how you work I suppose. Link to comment Share on other sites More sharing options...
ClarkeThrasher Posted June 11, 2019 Author Share Posted June 11, 2019 8 hours ago, Kbird1 said: You can rotate Plan Views I am not 100% sure about Sections or Elevations though ( no?) ..... BUT send a CS or Elevation to a CAD Detail 1st and you can..... M. Well alrighty then, Kbird1, thank you, looks like you have successfully rotated an elevation but i'm not quite sure what you mean by: "send a CS or Elevation to a CAD Detail." I'm going to see if a pure Elevation from outside the structure without text will rotate, it doesn't so your approach sending to a CAD Detail must be the way to go. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 11, 2019 Share Posted June 11, 2019 9 hours ago, Chopsaw said: Amazing how screen shots work. Nice idea Mick. A lot less work than rotating the drawing sheet unless you need it to be live as there does not seem to be an update cad detail button. All depends on what you need and how you work I suppose. True , it won't remain "Live" and Update, so you need to do a new one if there are changes made , but at the Point I am sending to Layout I am usually done with the Design Side of things , so there aren't many changes...I mostly use this for things like Typical CAD Details which also don't change often, being able to Rotate on 11x17 or 12x18 pages helps in some cases I have found. 59 minutes ago, ClarkeThrasher said: Well alrighty then, Kbird1, thank you, looks like you have successfully rotated an elevation but i'm not quite sure what you mean by: "send a CS or Elevation to a CAD Detail." I'm going to see if a pure Elevation from outside the structure without text will rotate, it doesn't so your approach sending to a CAD Detail must be the way to go. If you do a CAD Detail From View of the Elevation or Cross Section , then send that CAD Detail to Layout it is just CAD Lines and can be Rotated unlike a Live View , as noted above I mostly do this with Typical Details , so I can Clean them up in CAD before sending to Layout , so I tried it with a CS and Elevation and it works for those Views too. M. Link to comment Share on other sites More sharing options...
