flush boxed eaves
djhplanning
Does anyone know how I can get a flush boxed eave on one end of the roof and no boxed eave on the other end of roof using the same roof plane?  I suppose I could make 2 separate roof planes, but then on the 2d elevation views I would see a line where the 2 join.  Suppose I could just use a white with no border to cover this line up.  Also, there seams to be some type of bug in the program because sometimes I will set roof to flush boxed eaves and one end of roof will still have a boxed eave that extends to the fascia line instead of being flush like the other end of roof.   I've attached a plan file with this situation.  The area over the porch is the eave I want to match to the attached picture.  The boxed flush eave program bug is on the deck side towards the angled deck railing.
Richsmeier-Existing Conditions 6-10-19.plan
If you're only concerned with the line being on a layout and you send elevations as plot lines, you can delete the line in the layout view using the Edit Layout Lines tool:
1155119503_ScreenShot2019-06-11at4_16_19PM.thumb.png.03366514895a6c6156c827baaa3f6108.png
Chris,
Open the bow window dbx and on the Options panel check Use existing Roof.
Make sure you are in the floor plan view and go Build>Roof>Fix Roofs.
On 6/11/2019 at 7:09 PM, glennw said:
Chris,
Thanks Glen, that seamed to clear up the boxed eave on the deck side
Thanks Chris, that would be an option.  I try to minimize doing this because all the lines that are edited in layout this way will come back whenever the elevations are updated after a change.
