doors
decorators3
You import your door symbol that is in a format that CA recognizes. Then you put a door in a wall, select the door, open the door object (double click or ctrl+e) and then navigate to "Door Style" and click on "Library" to find the door you imported into the file.
It is possible to create your Own Inserts with CAD Lines , though if I remember correctly from previous Posts it only works on Chief's own Doors and Windows , not Imported models or ones from some of the Manufacturer's libraries, not sure if that changed in X11 as I haven't tried it.
Chief refers to it as Custom Muntins , there is a tutorial here :
https://www.chiefarchitect.com/support/article/KB-00930/creating-custom-muntins.html
