decorators3 Posted June 6, 2019 Share Posted June 6, 2019 Hi I want to import a door into my program for a house build.. how do I go about it?? Levina CA Premium 11 Link to comment Share on other sites More sharing options...
PerryPlansPro Posted June 6, 2019 Share Posted June 6, 2019 You import your door symbol that is in a format that CA recognizes. Then you put a door in a wall, select the door, open the door object (double click or ctrl+e) and then navigate to "Door Style" and click on "Library" to find the door you imported into the file. Link to comment Share on other sites More sharing options...
decorators3 Posted June 6, 2019 Author Share Posted June 6, 2019 thanks!! Link to comment Share on other sites More sharing options...
Dermot Posted June 6, 2019 Share Posted June 6, 2019 You might also find these articles helpful: https://www.chiefarchitect.com/support/article/KB-00117/locating-and-importing-3d-symbols.html https://www.chiefarchitect.com/support/article/KB-01808/creating-a-custom-door-symbol.html Link to comment Share on other sites More sharing options...
decorators3 Posted June 7, 2019 Author Share Posted June 7, 2019 thank you very much. Im not at all familiar with symbols and how they work or how to create the necessary dwg etc files for importing a door .. so maybe your second suggestion is an easier way to approach my problem... Link to comment Share on other sites More sharing options...
decorators3 Posted June 8, 2019 Author Share Posted June 8, 2019 its not so much the door.. its the glass insert that I need because its not in the program library Link to comment Share on other sites More sharing options...
Kbird1 Posted June 8, 2019 Share Posted June 8, 2019 It is possible to create your Own Inserts with CAD Lines , though if I remember correctly from previous Posts it only works on Chief's own Doors and Windows , not Imported models or ones from some of the Manufacturer's libraries, not sure if that changed in X11 as I haven't tried it. Chief refers to it as Custom Muntins , there is a tutorial here : https://www.chiefarchitect.com/support/article/KB-00930/creating-custom-muntins.html 1 Link to comment Share on other sites More sharing options...
decorators3 Posted June 8, 2019 Author Share Posted June 8, 2019 this is great i will save the link .. Thanks.. its exactly what i needed!!! Link to comment Share on other sites More sharing options...
