wncbw7 Posted June 3, 2019 Share Posted June 3, 2019 See attached image of stairs. I am going to have 3" thick treads so they can span the 42" wide steps. How can I delete the center stringer? Also how can I edit the side stringer size? Would like to change it to a 4" thick piece of wood. Link to comment Share on other sites More sharing options...
ShaneK Posted June 3, 2019 Share Posted June 3, 2019 No magic button for your wishes, manual work to accomplish what you want. Link to comment Share on other sites More sharing options...
Chopsaw Posted June 3, 2019 Share Posted June 3, 2019 Yes, create a section view and make a cad detail from view and trace your treads and stringers and make them with psolids. Chief stairs will just serve as your template. Link to comment Share on other sites More sharing options...
wncbw7 Posted June 5, 2019 Author Share Posted June 5, 2019 Thanks for the responses. Link to comment Share on other sites More sharing options...
parkwest Posted June 6, 2019 Share Posted June 6, 2019 Will this work for you? Link to comment Share on other sites More sharing options...
parkwest Posted June 6, 2019 Share Posted June 6, 2019 I took a closer look at your stairs and came up with this: Link to comment Share on other sites More sharing options...
