scout1 Posted May 30, 2019 Share Posted May 30, 2019 is there a way to duplicate a plan view then rename and save that view. after that is done can the call out labels be on in one view and off in the other. I turn on labels in one view then save that view. I then switch to the other view and turn off label and save that view now labels are off in both saved plan views? Link to comment Share on other sites More sharing options...
rlackore Posted May 30, 2019 Share Posted May 30, 2019 If both plan views are using the same layerset, then of course the labels will turn off in both views if you modify the layerset. Create two layersets - one for each view. Link to comment Share on other sites More sharing options...
robdyck Posted May 30, 2019 Share Posted May 30, 2019 You can "save" a plan view, and you can "save as" for a plan view. If you don't have the tool on your tool bar already, just look for it in customize toolbars. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 30, 2019 Share Posted May 30, 2019 1 hour ago, robdyck said: You can "save" a plan view, and you can "save as" for a plan view. If you don't have the tool on your tool bar already, just look for it in customize toolbars. Just a little tidbit here, but I actually just use the Save Plan View button for pretty much everything... - To save a plan view in its current state I just click as usual - To “save as“, I simply switch the plan due to ”None” and then click the tool - To create a new plan view, I switch to “None”, change other settings as necessary, and then click the tool. The only thing that you can’t really do without using the project browser or one of the other tools is is open a new plan view in its own tab. Link to comment Share on other sites More sharing options...
