sweetmelissa Posted May 20, 2019 Share Posted May 20, 2019 I asked this question before, got help, figured it out. Now, I'm trying to do what I did before and it is not working. I am at a loss. All I want to do is send two different views of a wall elevation to the layout... one normal section view set, and then a "no doors" layer set that I created by copying the section view and then unchecking "cabinet doors/drawers". It worked before... a couple months ago. Now, when I send my "no doors" layer set view to layout and then go back and change the active layer set to the section view set (with doors) and then send it to layout, the original view that I sent to my layout changes to the "with doors" view. THEN... when I go into the layout and click on the layer set button at the bottom which indicates which layer set its using, it SAYS it's using the no doors view... when it has obviously changed to the "with doors" view. I have tried to copy the layer set and rename it before sending it to layout and that is not working either. It changes whenever I make a change outside of the layout. I simply want to show a closet with and with doors... I know it's possible. I've done it before. If I sound frustrated, I am. I have tried for over an hour to figure this out. I have read articles and watched videos. If this makes sense to you at all and you feel like helping out, I would be ever so grateful. I would happily pay anyone to fix this problem for me. I am using X9 because I need to finish the projects I'm working on before trying to figure out the newer versions and how to switch everything over. The picture I have attached shows that the layout box clearly indicates it is using the "no doors" layer set, even though the doors are very visible! Thanks ahead of time to anyone who has time to help. Link to comment Share on other sites More sharing options...
sweetmelissa Posted May 20, 2019 Author Share Posted May 20, 2019 In case you are wondering if doors/drawers is actually unchecked. Link to comment Share on other sites More sharing options...
sweetmelissa Posted May 20, 2019 Author Share Posted May 20, 2019 A closet with several cabinets in it. But, to figure out how, I have opened a new plan and am using just these three base cabinets. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 20, 2019 Share Posted May 20, 2019 18 hours ago, sweetmelissa said: A closet with several cabinets in it. But, to figure out how, I have opened a new plan and am using just these three base cabinets. If you used Live View ( update automatically /on demand), when you sent to Layout , open the Layout Box DBX and switch it to Plot Lines and don't update one page or the other. That should fix the current issue, in the future use two different cameras. If using Live View when you send......you normally get a warning about the Layset Updating when making Changes made in Plan and what will happen. M. Link to comment Share on other sites More sharing options...
sweetmelissa Posted May 21, 2019 Author Share Posted May 21, 2019 13 minutes ago, solver said: There is probably a better way ... Agreed, but this isn't working when I do it. Even when I send it to layout and click that box, as soon as I go back and change the layer set used on the elevation, it immediately changes the one I just sent to layout. Which, now that I have tried it again... the only way it doesn't is if I don't click "update always"... like "M" said. This was not necessary the last time I did this. Link to comment Share on other sites More sharing options...
sweetmelissa Posted May 21, 2019 Author Share Posted May 21, 2019 When CA upgrades the program, does it affect the way prior versions work? Link to comment Share on other sites More sharing options...
SNestor Posted May 21, 2019 Share Posted May 21, 2019 16 minutes ago, sweetmelissa said: When CA upgrades the program, does it affect the way prior versions work? Can you post the plan? You'll get an answer fairly quickly... Link to comment Share on other sites More sharing options...
SNestor Posted May 21, 2019 Share Posted May 21, 2019 Just create two layer sets...one called Section View and another called Section View - no doors. Turn doors off in the "no door" layer set. Send each view to layout...easy peasy. Link to comment Share on other sites More sharing options...
sweetmelissa Posted May 21, 2019 Author Share Posted May 21, 2019 10 minutes ago, SNestor said: Can you post the plan? You'll get an answer fairly quickly... Ugh... yes. At the risk of being judged very harshly. I'm an Occupational Therapist/turned cabinet drawer... so please be nice. https://db.tt/1yb8GnS8w0 And, yes, I know it's easy peasy... but it's not working. Link to comment Share on other sites More sharing options...
sweetmelissa Posted May 21, 2019 Author Share Posted May 21, 2019 Starting at pg 18 in the layout... I'd like to do this with the laundry cabinet as well as "his closet" on the next few pages. On this layout, I just inserted screenshots of the "no doors" look in both rooms. Link to comment Share on other sites More sharing options...
sweetmelissa Posted May 21, 2019 Author Share Posted May 21, 2019 Did you do that video?? Thank you! Sooo... what I'm not doing is creating a separate wall elevation for the no doors view! LOL! OH MY GOSH. I honestly don't remember doing that before!! Link to comment Share on other sites More sharing options...
SNestor Posted May 21, 2019 Share Posted May 21, 2019 49 minutes ago, sweetmelissa said: Ugh... yes. At the risk of being judged very harshly. I'm an Occupational Therapist/turned cabinet drawer... so please be nice. https://db.tt/1yb8GnS8w0 And, yes, I know it's easy peasy... but it's not working. Oh, I’m not trying to be snarky. I’ve been exactly where you were....many times. Lots of people here to help you out. Link to comment Share on other sites More sharing options...
sweetmelissa Posted May 21, 2019 Author Share Posted May 21, 2019 1 minute ago, SNestor said: Oh, I’m not trying to be snarky. I’ve been exactly where you were....many times. Lots of people here to help you out. I didn't think you were being snarky... I was agreeing with you! Link to comment Share on other sites More sharing options...
