builtright3 Posted May 13, 2019 Share Posted May 13, 2019 I don't understand why I keep struggling with this cable not filling in. This is all automatic roofs and It doesn't seem like I should be having this problem. Plan is attached, any help would be appreciated. New Addition, Gullaba.zip Link to comment Share on other sites More sharing options...
DavidJames Posted May 13, 2019 Share Posted May 13, 2019 Your manually-drawn ceiling plane is preventing that wall from being generated. Link to comment Share on other sites More sharing options...
BryceEngstrom Posted May 13, 2019 Share Posted May 13, 2019 It's the custom ceiling plane that is suppressing the auto generation of the attic wall. To do the scissor truss vault, you need to custom edit that attic wall. Link to comment Share on other sites More sharing options...
builtright3 Posted May 13, 2019 Author Share Posted May 13, 2019 Thanks guys! This is one of those situations where they wanted to go over the top of the existing joist with new trusses and it led to a lot of out of the box thinking to make the plan work. I know there are other ways of doing this the way I did but this all works really well for the sections. I did all standard 2x4 roof framing and then put one trust joist in so it would pick up the look I want in the section view. Anyway I got the attic wall in and it looks good thanks to you. Link to comment Share on other sites More sharing options...
CharlesVolz Posted May 13, 2019 Share Posted May 13, 2019 Link to comment Share on other sites More sharing options...
builtright3 Posted May 13, 2019 Author Share Posted May 13, 2019 40 minutes ago, CharlesVolz said: Got it, Thank You Link to comment Share on other sites More sharing options...
