floor molding defaults x10
kieran989
HI Mark,
I know how to define the moulding for a single room. But I'm asking how to change the default base moulding under default settings? Mine is greyed out when I go to default settings>floors and rooms>current floor>moldings
41 minutes ago, kieran989 said:
HI Mark,
Not sure why you cannot select and change default. Are you in your template plan or opened in a new plan?  Either way it should only be necessary for you to go to your default settings>Floors and Rooms>Edit>Current floor>Moldings and change it there.
If you change it in your template plan, then each time you start a new plan using that template it should remain as you set it. Perhaps if you posted the plan you're having this issue with you will get a good answer?
