Terrain Problem
builtright3
3 hours ago, builtright3 said:
You would think that the "Break Terrain" tool would have solved that issue.
There is no Break Terrain tool.  You can break an Elevation line, and you can use a Terrain Break.  Probably best to clarify which one you're talking about or if you're talking about something else entirely.
Your original post said you tried the "Break Line" tool which is a tool, but it could have been used on your Elevation Line or on your Elevation Region (closed elevation polyline).  Then your last post referred to a "Break Terrain" tool which isn't a thing at all.  There is a Terrain Break, but you didn't have one of those in your plan.  What you did have however were some Terrain Retaining walls which have a sort of built in Terrain Break functionality.
    31389
    LeighSupplies
    LeighSupplies
