Chamfered cabinet corner
Larry_Sweeney
56 minutes ago, Larry_Sweeney said:
Is there a work around to make a chamfered corner on a cabinet stile?  2056336847_chamferedcorner.thumb.JPG.0cc0c729959a07cce9c29f3072611bd5.JPG
Stopped into the office and had found some millwork symbols I had, converted to a door (may already have those but didn't look further) Here is plan with cabinet and two door symbols, left and right. You can go from there.
chamfer cabinet.plan
  • Upvote 2
Mark...............................Thanks for all the info. What you are showing is almost exactly what I'm after. Now I'll have to do some homework to understand just how you did it.  :unsure: I'll be going through your threads on the subject and I'll also look for some other training (video/knowledge base) material. Thanks again for your time and knowledge and have a great day.
There aren't going to be videos, open the cabinet dbx to see settings. It's a matter of splitting the face, then delete what isn't needed from the vertical layout you want the chamfer on, resize the layout and change to side panel inset.
Then open the symbols to look at stretch zones.
